after you go to "search " this is for replys to joesph e meehan, the same mountainbike, cappy208,ranck,& ok4450. first of all i thank you for your time. if you now read “search” i did find where the pcv was located.it was down on the driver side down towards the top of bell housing. i took it out & down inside i used a long needle nose pliers to remove this one inch long screen. it was hard to get out but i got lucky. bought another one &got very lucky again . there are no more leaks… engine is 302. just wanted you guys to know there was a screen or filter??? below the pcv… again thanks for the input
Related topics
| Update for joseph meehan,the same mountainbike.cappy208,ranck,& ok4450 | 0 | 261 | October 17, 2007 | |
| Update for joseph meehan,the same mountainbike.cappy208,ranck,& ok4450 | 6 | 662 | October 18, 2007 | |
| Oil leak | 2 | 371 | August 20, 2007 | |
| 87 lin oil leak | 9 | 923 | August 22, 2007 | |
| What causes PCV fails quickly? | 67 | 8583 | March 8, 2021 |
