After comparing the Haynes wire pin out and color code, I find that that it is not correct for the 86 Ca. smog. The pin numbers are molded on the connector body. If Tester is out there, do you know what the connections to sensors are? this is a follow up to previous question. PS, how do you know so much about this? and thanks for past help too.
Related topics
| Toyota 1986 | 7 | 1103 | January 30, 2010 | |
| Wireing | 5 | 856 | January 22, 2010 | |
| Thanks from square one | 0 | 437 | February 10, 2010 | |
| Need Help On Pinouts For ECM | 4 | 692 | January 23, 2010 | |
| 99 dodge dakota obd2 connector replacement | 2 | 4807 | November 6, 2010 |
