250cc foxico buggy wont go in reverse
Hi my 250cc 2 seat foxico buggy wont go into reverse and neutral goes forward and so does drive still but sometimes doesnt go when in drive
Check transmission cable or linkage to be sure it hasn’t changed position due to stretch or wear.
250cc? Pick the front end up and turn it around. :wink:
Seriously, you got good advice above on where to start.
TwinTurbo the cables are all fine tried it without the cables just by hand puking the transmission lever still didn’t work
Not sure I want to see that.
Well, sounds like the transmission part of it is broken then and engine will need to come out for repair…
