2025 Ford Explorer - Misfire issues
Random misfire changed p300 p301 (after new fuelinjecyor 301 went away300 remained)
Spark plug
Coil pack
Injector
Purge valve
Might help if we had the correct information on your vehicle, I really don’t think you are chasing misfire codes on a 2025 Ford Explorer…That would be a factory warranty repair for the dealer to handle…
Give us the correct year, make, model, engine size, mileage and maybe even the 2wd or 4wd/awd…
Agree with above post.
Another thing that will cause a misfire (normally at idle) is vacuum leaks coming from a large vacuum hose or the intake manifold gasket.
Ford 4.6 and 5.4L intake manifold gaskets are made of plastic and are notorious for causing engine misfire conditions
