2024 Acura RDX - Premium or is regular ok?
I think your lawnmower engine posts are both interesting & informative Bing. The lawnmower engine makes for an effective prototype for all gasoline engines, and is much easier to experiment with than a car engine. Prototypes are a common practice scientists use when wanting to make the best use of their resources when studying a topic.
I do concur w/ @Nevada_545 's apparent objective of attracting more first time posters here, but banning lawn mower engines from the discussions here seems the wrong way to do it.
In WA you pay tax then if its at least 41gal/yr you can get a rebate for specific uses such as lawn care or boating.
I’m not going to suggest lawnmower discussions be banned however the OP has an Acura, how many times should Bing offer lawnmower advice? If you want to hold your own discussion start a new one.
You left out the word repetitive.
After 62 posts you’d think the message to not use regular in his/her/its Acura would be clear. But at least we know what the ratings are in Vermont.
Actually I have found those forums to be of little use. Like here the answers are all over the place and you just pick the answer you agree with.
I’ve never used those, but I do use some bicycle-repair forums. While the answers do tend to wander, and there’s a lot of useless in-forum debates based mostly on the poster’s ego , usually if I’m patient enough there’s someone there who will post something informative. I may have to wallow through 20 impertinent posts and personal insults first. But that’s the price paid for ā€œfreeā€ information.
While using less than Premium High Octane gas will probably never damage your engine as the ECM will probably adjust, using lower octane Regular will reduce the additional HP on the vehicle that you paid for.
So why would you pay the extra big bucks for the the high performance turbo charged engine if you’re going to cheap out on the gas and end up with lower performance?
One motivation might be the car payments are making you are low on cash, so you have to reduce spending on something else to bring your budget into balance.
We are talking less than $10 a tank full, A tank a week is $40 a month,
If $40 a month is going to cause that much problems, They can’t afford the car to begin with.
Unfortunately that situation is all too common.
I can’t count the times I’ve heard someone say they can’t afford to do all the maintenance on their car. When in fact people afford what they want to afford.
What is almost worse is the people that run 89 or 93 octane when the vehicle calls for 87 octane, same thing but in reverse, now the engine is less prone to spark knock so the engine advances the ignition timing more than needed for optimum performance and fuel economy, and they get reduced fuel mileage now… Run what is recommended for the vehicle, no matter if 87 or 89 or 93 octane… If you need a higher than recommended octane fuel then something is causing your engine to spark knock, like to much carbon build up etc etc… (in a stock engine)
Yes, but some people have very strange ways of ā€œsavingā€ money. A friend of mine was always complaining about being short of cash, but instead of making a peanut butter & jelly sandwich at home, for her lunch at work, she bought Uncrustables, which cost a LOT more. When I pointed-out the price differential to her, she said that she didn’t have enough time each morning to make a PB&J sandwich.
Huh? :thinking:
This was the same woman who used to tell me that she ā€œsaved moneyā€ by paying for everything with cash, instead of using a credit card. But, because she always drove her gas-hog Buick to the bank at least two times between paychecks in order to get more cash, she clearly wasted money that she could have saved by paying with a no-fee credit card.
So your friends and neighbors will marvel at the expensive, luxury vehicle you have parked in the driveway…
In Chicago at the last Shell station I went the difference was a $1.40!
$3.89 vs $5.29.
There is no way premium would give better gas mileage than regular if the car does not require it.
But if it does require premium then you’d get better gas mileage and better performance.
Totally agree. Using regular in a premium required car would probably knock like crazy. And possibly ruin it.
I previously had a Focus ST that only required regular but recommended premium.
One day I had a trip from Chicago to Harrisburg PA. It was all toll roads and same weather conditions throughout. Same Sunoco stations all the way. So I tried both regular and premium along the way. No difference in mileage.
My Escape now has the same engine. So I just use regular.
That is what the knock sensor is for, it should/will pick up any preignition (spark knock) before you will ever hear it and retard the ignition timing to prevent engine damage, but retarding the engine presents even more issues…
Usually higher compression ratios require a higher octane or cars that are turbo or super charged. When you use a lower octane then what the vehicle was designed for - it could cause knocking. Cars do have knock sensors that will retard the ignition time to prevent this. When it happens you get less performance and worse gas mileage. On some vehicles sometimes under hard acceleration the knock-sensor can’t retard ignition enough and engine will continue to knock. Excessive knocking can DESTROY your engine. I’ve torn down an engine that was destroyed from excessive knocking. 2 of the pistons had large holes burnt through them. Engine and block were junk.
Red Bank? Freehold roads?
