car brakes throw you forward unless your extremely carefull. can they be adjusted ?
No adjustment, but if this behavior of the brakes is different than when you first bought the car, you should have the system checked. Perhaps this car simply uses much less pressure on the pedal than your previous car?
thanks for the reply about brakes.
