2016 Mercedes-Benz GL-Class - How much for shocks?
Need rear shocks replaced, how much will it cost?
Depends on if you want good, better, or best. I would avoid trash-o-matic.
Might be better to trade your M-B in on a new nice vehicle, like an Expedition or Explorer.
Welcome, your Ask Someone question has been redirected to Car Talk…
You gave us incomplete information about your vehicle, is it a GL350, GL450, GL550 or a GL63 AMG??
Looks like the labor only for the rear Air Ride Socks on the GL350 is about 5.3 hours for both rears, plus alignment if required, the rear shocks are around $900.00 each at Napa if available…
So find out what your shop labor is per hour and multiply that by
5.3 hours…
If the shop labor is $200.00 per hour then their labor cost would be $1060.00 plus alignment and parts…
So guessing the alignment will be $200.00, then you are looking at about $3,060.00 for rear shock replacement depending on the cost of Parts (dealer may be higher), Labor, Alignment, Shop Supplies and any other Misc Parts and or Labor required to do the job in your area on a 2016 GL350…
Whenever you give us all the correct info I will try to get you the rough price in the Nashville area, your area WILL differ…
Also need to know if you have the W/ Adaptive Suspension (ADS) or with out ADS??
