all 4 windows do not work, driver side i believe is off track but none of them work, what is the problem?
maybe there is a problem with the buttons or the relay. try to connect a tester and see if you have any errors
From July of 2020…
2016 Hyundai Tucson - Cheap window regulators - Maintenance/Repairs - Car Talk Community
CSA
If none work (no sound or action or slight dimming of an interior light from the motors running?) it could be the fuse for all blew because the motor for the jammed window pulled too much current. Check the fuse. If not the fuse, it’s some other place in the electrical path that is common to all four windows.
Ty i will check that
I do believe the front passenger window is off track, sometimes the left back window will work
