The battery just dies. Completely dead. After a jump start it will run again for awhile. Then dies again usually over night. Nothing left on to drain battery. Have had it towed in 6 times over last 2 years. The tow truck driver has to jump it to get it into neutral. Then the dealer says can’t find anything wrong. Can anyone help??
If this is the original battery it may need replacing. Each time a battery is depleted it reduces its capacity.
With a fresh new battery have the charging system checked and check for parasitic draw. Since this has been a problem for two years and is documented by Ford, I would think warranty should apply. Battery itself is, at best prorated.
If the use of your vehicles is just short trips, the car may not have time to fully recharge.
