front hood vibrates at higher speeds and when it hits bumps…
first make sure the hood is shut properly. then check to make sure the front latch is not loose or broken.
also as a last resort. there are rubber bump stops on a threaded rod that you can adjust up and down. but you should really find out what the real issue is and fix it. the latch bolts might of loosened up and made it out of adjustment.
