My clutch is itermittently squeaking, but it doesn’t seem to be hindering my ability to drive and performance seems the same. Should I be concerned?
Probably, can you tell where the squeak is coming from.
Maybe, maybe not. It’s probably the clutch pedal that’s squeaking. If that’s the case you may be able to solve the problem with a squirt of WD40.
