2013 Volkswagen Passat - Clicks
Automatic door lock clicks on and off every time the speed either goes above or below 10 MPH?
Are you asking if the locks do that or do you have a problem ?
Sounds like a door ajar switch is failing, does the door ajar indicator flash on and off?
There is a problem with the locks – the continually lock and unlock.
The door ajar indicator does not flash on and off.
Many cars allow the programming of door locks to automatically lock above a certain speed. It is something you can usually set yourself. Sometimes the dealer needs to do this. They should not un-lock at all, even if dropping below the set speed. I’d suggest a visit to the dealer or a well respected VW-Audi independent shop.
