hi my vw Passat 2014 automatic door lock is not working. when I drive the car I get door lock sound, but still can open from inside with puss unlock button.
As I recall, on an older Passat, that lock function locks the doors against someone outside opening the door.
You need to be able to open the doors from the inside in case of emergency.
what is a “puss unlock button” ?
