2004 jetta, interior lights & door open light on dashboard intermittently come on and off while driving.
Noted.
Assuming you want to fix it, check that all doors are closed.
One of the light switches in the doors may be faulty, or a door may not be closing completely.
Checked and rechecked; all doors and trunk shut / lock properly…
Bad switch.
It’ll be a little plastic sliding thing that the closing door moves into position. If it goes bad the car doesn’t know that the door is closed.
Check the contacts for the dimmer control.
