Your RAV4 should easily hit 200,000 miles as long as you keep up with maintenance. If you save for a new one you should have enough money over the next 8 years until you hit 200K.
Re: Chart in post 15
I wonder if a window that doesnāt move b/c the switch is faulty is considered a window problem, or and interior accessories problem? & how is it categorized if the problem is a faulty window motor?
The complaint is about the window switch(s) failing to work and having to be replacedā¦
And Car Complaints has it listed under Window Problem not interior accessories problemā¦
