2013 Ford Edge - Clunks
Clunking noise when coming to a stop. Ford dealer changed break booster but it didn’t solve the problem. Is it safe to drive. Can you help?
Most likely there’s worn suspension parts. Could be control arm tie rods, ball joints, steering rack, amoung many other things. Nobody here can tell you if it’s safe to drive because we can’t see it. If it’s clunking that means something is loose. The next step to a loose part is falling off. So I would assume it’s not safe to drive.
