It sounds like you got a good start on a solution, but no matter how good the replacement motor is, it won’t do the job properly if the mechanism that raises and lowers the window is jammed and/or corroded or needs lube. In fact if there’s something amiss there, it could damage the new motor. Sort of like replacing a garage door opener, first step is make sure the door is properly counter-balanced & opens and closes smoothly by hand.
| 06 Ford F-150 Drivers Power Window working intermittently | 12 | 11938 | March 11, 2015 | |
| My car's driver side power window isn't working. What is wrong and how can I fix it? | 20 | 77432 | February 6, 2013 | |
| 2013 Ford Edge - Window switches quit | 1 | 364 | June 23, 2020 | |
| Passenger window motor needs replacement BUT no power to lower in order to remove it | 22 | 2305 | July 2, 2022 | |
| Power Window Problem-Help rain is coming! | 5 | 681 | June 2, 2009 |
