2013 F-150 starting system fail
Fabric and foam wrapped around the drive shaft. How would I do a ignition reset?
You lost me in the translation to english.
Why do you think you need to?
Oh, please stop adding posts for this problem. Just reply to THIS post.
Obviously you need to reboot the flux capacitor first. Then recalibrate the doohickey and plug in the thingamajig. That may fix it.
You don’t need to “reset” anything. You need to repair the wiring or components that were damaged by this adventure.
I’m guessing OP’s truck cranks but won’t start after some debris wrapped around the driveshaft. Assuming driveshaft is now free of all debris, suggest first test is to measure the voltage at both starter motor terminals, thick and thin wire, with key in “start”. Both should measure at least 10.5 volts. Probe with volt meter from terminal to starter case. If you post the result here I expect you’ll get some further ideas.
Much appreciated. Ty to all
This was my first post- the answers at first were amusing and mostly sarcastic. That’s maybe on me for not a better explaination . Yes the foam fabric is cleared. It wasn’t complicated. We ran over some stuff & it wrapped up tight.
The solution was to disconnect the P&Neg on the battery, wait five, touch them and reconnect. That solved it. :joy::+1:
Hoping this helps the next person…
A pic may help to illustrate a problem. I would say I ran over something. This is what it looks like. Now my car won’t crank. You think there is a connnection? Many people cannot explain their issue? You are one of them. You don’t think you were vague?
OPs 1st post about the issue…
The picture didn’t really help, did it? Some explanation of what the truck wasn’t doing would have helped.
Glad it got fixed.
It’s definitely a puzzle how debris wrapping around the driveshaft would prevent the engine from starting. The driveshaft isn’t even doing anything when starting the engine. One theory, the driveshaft problem occurred while truck was being driven, in gear, & when driveshaft wouldn’t turn, that stalled the engine, creating some sort of electrical glitch which confused the computers. Computers were so thoroughly confused they refused to start the engine. Disconnecting the battery resets the computers. A reset done w/that method sometimes causes other problems though. Fortunately it appears those problems didn’t occur in this case, and OP’s F-150 is back to being a reliable driver. Thanks for the follow-up OP :slight_smile:
