2012 Jeep Patriot - Help with fuse location
headlight not working but bulb is good, can not locate the fuse for right headlamp to checkl
The headlights are protected by the Totally Integrated Power Module.
There is no fuse.
Thank You, I didn’t think I was missing it…I will test my wires to rule that out.
I have actually had a few of the other issues associated with the TIPM…time for a trade…
DawnM
Check the ground for that light.
Thanks for the help, has power, ground wire next.
