2012 Chrysler 200 headlight relays?
are there relays for the headlights on a Chrysler 200 touring 2012 model. I found the fuse for the lights but no relays. driver side does not work on hi or low beam.
First check to see if the bulb is OK. Then check to see if there is voltage going to the plug for the bulb (s) . If no voltage start tracking the wires back to look for breaks, evidence of rodents chewing on the wires. Verify that the fuse is OK with a multimeter. Sometimes fuses look ok to the eye but have a hidden break in them.
There are no relays for the headlights
The headlights are controlled thru the Totally Integrated Power Module.
