No power to the a/c climate controls/ no blower motor NO power at all to the controls. I checked every a fuse and relays and good.
If the blower motor is toast then nothing will work.Changing it is not difficult
You checked fuse 23, for the power dist center, right? Fuses are often spread around, located under the dash, and under the hood in the engine compartment are common areas to look for fuses. Do you have the manual climate control, or the automatic climate control? They apparently made a change in the design on March 5, 2012. Do you know what day your car was built?
It’s a manuale climate control
Mail](https://go.microsoft.com/fwlink/?LinkId=550986) for Windows 10
