2011 Nissan Rogue - Engine issues
the car starts up fine, idle is a little rough, engine light not on. When acelerating it sutters and engine light starts flashing. I replaced the MAF sensor when symptoms first appeared. It still has the same symptoms,
Flashing check engine light indicates a misfire, the fault code in the computer will indicate which cylinder. Likely a spark plug or coil problem.
Did you read the code? If so, what was it?
You’re aware that driving a car with a flashing check-engine light can cause damage, right?
