2011 Mercedes-Benz CLS-Class - gas smell when topped off
i purchase this car about 4 yrs ago when the car is topped off there ia strong scent of gasoline , a local NJ dealer told me ths item has not been taken care of by MB . i am planning on bringing the enclosed article to the local mb and see if they will follow up , or i am planing a smalll claims against mb as well as case for triple damgages as allowed in Mass.
You bought a used vehicle out of warranty and you think you have a Small Claims issue ? Good luck with that . Just have an independent shop solve the problem and be done with it.
  1. We can’t see any article.
  2. You will not prevail in court so save your money for a mechanic to fix the problem.
you should not be topping off the gas. just stop when it clicks off. that is probably why you are smelling the gas fumes.
Why you should never 'top off' your gas tank
Don’t top off, and have your car’s evaporative recovery system tested.
There’s a problem with the over-fill/roll-over check valve in the Onboard Refueling Vapor Recovery system.
