2011 Hyundai Genesis - Screen freeze
screen freese 2011 genesis
That’s probably going to require a dealership shop. About the only thing you could try is ask your shop to disconnect the battery overnight, perhaps a total system reset will get it working again. Be aware however that disconnecting the battery can cause other problems, like loss of learned idle parameters, so engine may not run well, or might not even start.
