Is it safe to drive with ABS light on
As long as the vehicle stops good under normal braking then yes, but keep in mind the ABS most likely will NOT work in a emergency braking situation… So it will not be as safe, but the brakes should work as normal, but will lock up like before vehicles had ABS…
