Why is my brake light and battery light coming on at the same time? My mechanic says theres nothing wrong with my brakes
Offhand I’d suspect a failing Body Control Module. https://moduleexperts.com/5-common-symptoms-failing-body-control-module-bcm/
The battery symbol is the charging system warning light, the alternator may be failing. Low charging system voltage can cause the brake warning lights to illuminate.
