2011 Buick LaCrosse - It's got that shimmy
during long drives the front end has a shimmy in it for about 10 miles or so. pulled over and ckd for loose lug nuts.All secure…Just had a couple new tires put on and had all 4 balanced and aligned… seem to loose pwr brakes during that time …Hit the brake pedal hard a couple times and the problem cleared…Maybe ABS???
2011 Buick LaCrosse Recalls
Suspension
NHTSA CAMPAIGN ID:
21V00F000
Report Date:
December 22, 2021
Vehicles Affected:
4,271
Consequence:
A rear toe link fracture may reduce the driver’s ability to control the vehicle, increasing the risk of a crash.
What You Should Do:
Dealers will replace the rear suspension toe links and adjuster fasteners, free of charge. Interim notification letters notifying owners of the safety risk will be mailed January 27, 2022. A second notice will be sent once the remedy is available. Owners may contact Buick customer service at 1-800-521-7300 or Chevrolet customer service at 1-800-222-1020. GM’s number for this recall is N212346640. This recall is an expansion of NHTSA recalls 20V-764 and 21V-633.
Summary:
General Motors, LLC (GM) is recalling certain 2010-2013 Buick Lacrosse, 2012-2013 Buick Regal, and 2013 Chevrolet Malibu vehicles sold or ever registered in Connecticut, Delaware, the District of Columbia, Illinois, Indiana, Iowa, Kentucky, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, Virginia, West Virginia, or Wisconsin. These vehicles may have rear toe links that received an improper amount of electrocoating (e-coat) corrosion protection, which could cause the e-coat to become brittle and break away when contacted by road debris. Over time, the e-coat may chip away, exposing the metal toe link and making it more susceptible to corrosion. Corrosion may eventually cause the toe link to thin and ultimately fracture.
To see if your specific vehicle is affected
Enter Your VIN
Tip: Recalls don’t affect every vehicle of the same year, make and model. You’ll need your car’s 17-digit Vehicle Identification Number (VIN) to know for sure.
Where Do I Find My VIN?
Suspension
NHTSA CAMPAIGN ID:
20V764000
Report Date:
December 10, 2020
Vehicles Affected:
213,128
Consequence:
What You Should Do:
GM will notify owners, and dealers will replace the rear suspension toe links and adjuster fasteners free of charge. Parts are not currently available. Owners will be mailed an interim notification on February 15, 2021. A second notification will be mailed when parts are available, currently expected to be around March 21, 2021. Owners may contact Buick customer service at 1-800-521-7300 or Chevrolet customer service at 1-800-222-1020. GM’s number for this recall is N202308930.
Summary:
General Motors, LLC (GM) is recalling certain 2012-2013 Buick Regal, 2013 Chevrolet Malibu, and 2010-2013 Buick Lacrosse vehicles sold or ever registered in Connecticut, Delaware, the District of Columbia, Illinois, Indiana, Iowa, Kentucky, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, Virginia, West Virginia, or Wisconsin. These vehicles may have rear toe links that received excessive electrocoating (e-coat) corrosion protection, which could cause the e-coat to become brittle and break away when contacted by road debris. Over time, the e-coat may chip away, exposing the metal toe link and making it more susceptible to corrosion. Corrosion may eventually cause the toe link to thin and ultimately to fracture.
Enter Your VIN
