roaring noise like increases in volume as speed increases
Do you have the original tires on the rear of this car? If you do, put them on the front and see if the roaring moves forward. If it does, replace the tires.
It could also be a wheel bearing going bad. If it fails, really bad things can happen. Get it into a repair shop.
