Have a noise that rotates with the front right tire. Rotated tires. Still there. Is loudest at 20mph, although I’ve heard it at a slightly higher level of speed. (The transmission fluid is full) so not sure it’s that problem. Are the Buick Enclaves known for having wheel/transmission problems?
Brakes, wheel bearing or C/V joint in order of likely hood. If it is wheel bearing lt will be louder turning left.
