The air conditioner in my 2010 Toyota Corolla is working but is not as cold as it used to be. What could the probem be? What do you suggest I do? Finances low. Thank you.
If finances are too low to take it to a qualified A/C specialist, then either deal with the weak A/C and/or use your windows. A/C systems are not DIY fixable, and messing around with them (like adding a can of autostore refrigerant) will make some shops not want to mess around with your system as they won’t know what you added to the system
