2010 Ford Fusion tire pressure fault
What would cause a tire pressure fault indication on my dash board and a tire sensor fault as info. Yet the fault clears on its on.
Have you checked the air pressure in all your tires?
Failing tire pressure sensor. Eventually it will fail completely.
The life span of tire pressure sensors is about 7 to 10 years .
If your tire pressure is just low enough to trigger the light when the car is cold, just driving the car warms the tires enough to raise the pressure.
