Got code to change evap canister solenoid, changed it but still getting the code
I assume you had code p044X of some description. It would help to know the exact code. I know sometimes it takes a bit of driving before the check engine light goes out after a repair. Just a guess but this might be one of those cases–or you haven’t corrected the problem.
Has anyone used their reader to reset the code after the repair?
Purge valve solenoid?
Or vent valve solenoid?
