Transmission will not go forward or reverse will go gear but want move
Welcome to the forum…
It would be nice if you used punctuation, as it would make more since… Also don’t know if you are asking a question or just making a statement…
We also need more info… does the engine rev up really high but the vehicle doesn’t move at all in gear?? or does the engine just rev up a little but the car doesn’t move at all…
Could be the transmission is very low on fluid and can’t move under it’s on power…
Could be the brakes are locked up not allowing the vehicle to move… Like e-brake stuck on etc…
Lift the vehicle safely and see if the wheels will rotate any, also check transmission fluid level…
Could also be a bad transmission…
Could be a broken axle…
