1993 saturn sports coup with 230,000 miles. When steering wheel is turned completely to the left or right when trying to park, automatic transmission will not go into reverse gear.
Exactly what is not happening? Does the lever not move or does the lever move without the transmission engaging?
If you shift into reverse before you turn all the way, what happens?
