2008 Nissan Rogue - Won't start due to no fuel
fuel not getting through and it wont start
I would first check all fuses or relay for your fuel pump. but most likely you need a new fuel pump.
Are you sure you have gas in the tank. there is a service bulletin on the fuel gauge not working properly.
Nissan TSB NTB-09-009 — 2008 Rogue | CarComplaints.com
also, you should be aware of this recall.
Microsoft Word - Nissan Recall 15V-032 Owner Notification Letter
Suggest to explain why you think this is a fuel issue. There’s other possibilities, the most likely is a no-spark issue. Knucklehead diy’er opinion, no 2008 Rogue experience.
Are you 100% sure there is no fuel pressure?
I suggest confirming this with a fuel pressure gauge before making assumptions
Someone needs to fix it then.
