2008 Honda Civic doesn’t start
my car didn’t want to start;i m tring to start it more time even now not not turning engine to start what problem
Do you hear that rrr rrr rrr sound, but it won’t catch and run? Is that the problem?
Check the battery and terminals , if not might be the starter
If the vehicle has an automatic transmission, with the dash lights on, step on the brake pedal and shift the transmission into neutral, and then try starting the engine.
If the engine starts, there’s a problem with the transmission range switch.
If you don’t hear sound when you try to start it, the starter isn’t spinning. A likely cause is a faulty battery. If you have the original battery in the car, it is probably time for a replacement. Expect to pay about $125 plus labor to replace the battery.
