First time poster - I apologize for the long post.
I wanted to ask around and get some feedback before taking the car into a shop.
I have a 2008 Honda Civic with 63K Miles.
I am having problems with the AC/Defroster. AC blows cool but not super cold air when driving.
However when stopped or in stop and go traffic, at best I get best cool air.
There is a noticeable higher pitched whooshing/blowing sound when the compressor engages - imagine a jet engine spooling up for takeoff.
The Defroster does work well enough to clear the windshield.
To date, it has not blown warm or hot air.
In addition:
- I have checked the compressor/clutch and it does engage when the AC is turned on.
- I have not seen any issues with the Belts locking up, fraying etc…
- Both Radiator and Condenser Fans run. Have checked for debris etc…
- Condenser does drain.
- No water in the car from a plugged drain.
- Noise is Not present when only the Fan/Vent is running.
- No OBD2 Codes were generated.
- Checked the AC Pressure late last summer. With an outdoor temp of about 90+ Degrees. The Low Port showed roughly 37 PSI. High port showed about 160 PSI. I believe but I am not sure that these numbers were low.
- Recharged the System at when it was about 90+ degrees. System would not pressurize past 38-40 PSI on the low side even after using nearly an entire can (unfortunately I did not have access to a high port gauge when I recharged the system).
This did make any difference.
Thanks in advance for any ideas!
Larry
