My truck stop sating, going it seem the fuel pump starts an goes on it’s own I changed pump ,rail sensor ,cheaked fuses,it works aday or two sometimes then other times its an switch the key off an on you’ll here the fuel pump clicking times it’ll work an then stops .i can drive it an ten starts doing again
Can you repeat that again in English, I can’t make any sense out of it.
