2008 Citroën DS - Can I do what no other human wishes to do?
Can you put a stop/start engine into an older Corsa that has no stop/start function?
With enough time, money and fabrication skills you can put almost any engine in it.
Short answer, Yes, long answer, how deep are your pockets??..
A different answer, just turn the key off when stopped… You have to be good at timing your red lights, but I did this when driving my fun car a lot at longer red lights in the hot summer…
The stop/start feature is a function of the engine computer. If the replacement engine is mechanically the same as the old engine, it will function as it should (no stop/start).
Most often asked question: “how can I defeat start/stop”.
My question for you, why would you spend a lot of money to add a “feature” that places extra strain on your battery and starter?
