power window isnt working changed switch and regulator still no power
Can you measure 12 volts at the motor?
Is there a ground at the motor. You need both. The switch should reverse which wires get which.
Just one or all four? If it isn’t the driver’s window, can you lower it with either the switch at the door or the driver’s window console?
