Hello , my abs light shot and sometimes i donnt have brake what to do ?I CHANGED BRAKE PADS ALREADY
THAT ISN’T THE PROBLEM!
I am going to assume that “abs light shot” means the ABS light is on. Could be several things. the first of which is there enough brake fluid? Second, “donnt have brake” means there are NO brakes or just really poor brakes? If the pedal is dropping to the floor, the master cylinder may be failing, or even the ABS unit may be failing.
In any event, your FJ needs brake service right now! Tell the mechanic what is happening and let him find the problem. Good Luck
