I found this…
Saturn Mechanic: Dave Nova
Hello and thank you for using JustAnswer. My name is ***** ***** I will do my best to help you with your Saturn problem.
Most of the time this is due to an evap purge solenoid that is sticking open. This allows all of the fuel vapors to be sucked into the engine and floods the engine on startup after refueling. The purge solenoid is located on the engine, near the intake manifold.
