2007 Saab 9-3 - Stalls
2007 Saab 9-3 Anniversary Issue. Sometimes when car is hot the car starts then immediately stalls. I have to feather the gas pedal to keep it running for a few seconds and then it runs perfect. Whats up.
Try cleaning the electronic throttle body,
AND the idle air control valve.
Thanks. Will attempt to clean both.
Do you know how to clean an electronic throttle body?
Any info you can give me will be helpful.
Thanks. I was going to use Brake Clean. Will attempt this tomorrow after I purchase throttle body cleaner.
