does a 2007 IS 250 awd have an electronic suspension, or is that suspension only offered on rear wheel drive 250’s I need struts my rear tires are cupping.
This question is easy. All you have to do is ask the parts department at your local Lexus dealer and you will have the correct answer . Or if you are having the work done the shop will put the correct parts on.
The 2007 IS 250 does not have adjustable shock absorbers.
Thanks for your response
