2007 Honda Accord
I can’t seem to be able to remove the air filter box cover on my 3 liter V-6.
I can loosen the 4 screws,but can’t swing the cover away so as to remove the filter.
What am i missing?
Thanks
The screws may be longer than you think. Try unscrewing them farther.
I am able to to move the cover off the housing,but not enough to swing it out of the way to lift filter out of housing.
Are You Sure This Is Not A Situation Where The Cover Hinges Open A Bit And Then Unhooks To be Completely Removed ?
CSA
The cover has a 3-4 inch flexible snorkel that connects to the F.I. injection.
The problem is that i can’t get enough snorkel movement without disconnecting 3 emission lines on the snorkel.
Is A 2006 Accord Similar ?
http://www.ehow.com/how_6027103_install-filter-2006-honda-accord.html
This thing doesn’t say whether it’s a four cylinder or six cylinder engine. Does this make any sense to you or isn’t it correct ?
CSA
Well, i found the procedure on “youtube”, with pictures. Ditto for changing the cabin air filter.
Thanks to you all that replied
