The history of my car if was water damage.
Okay,  have it inspected.  If water only up to doorsills you are probably safe buying it, but wheel bearings and brakes must be thoroughly inspected.  If engine was under water-RUN.
BTW, fresh or saltwater, if saltwater, I would not even consider the vehicle.
OK, its your car,… Has it ever been under water since you’ve owned it?
Did you just buy it? Did you buy it without a CarFax or AutoCheck or one of these services AND an inspection by a mechanic? You can still run a background check on your car to see if it was a salvage car, or resided in Texas after Harvey or similar hints like that.
