2006 Toyota Camry LE with 118K miles. A/C was blowing cold but would go from cold to hot without changing any settings. Now it hardly ever blows cold at all. Closed side vents and put a thermometer in center vents. Once in a blue moon temperature will read 45F but will not last long. It’s 80F outside and temperature with full cooling is 65-70F most of the time. Compared passenger side vents to driver side and passenger side vents are constantly 15 degrees cooler…driver side is over 80F. I don’t hear any unusual noises from blend door. Suggestions appreciated.
Duplicate Post.
Related topics
| 2006 Toyota Camry LE with 118K, A/C not consistently cold....normally hot | 1 | 279 | April 25, 2019 | |
| 2008 toyota camry ac not working | 8 | 2814 | August 15, 2022 | |
| 99 Toyota Camry - AC is not conditioning | 1 | 376 | May 29, 2008 | |
| 2018 Toyota Camry Hybrid - Once-sided AC | 6 | 201 | April 26, 2025 | |
| HELP! 2005 Toyota Highlander Passenger side A/C vents blow cold air Driver side Hot - no dual temp | 2 | 6128 | July 21, 2011 |
