what to do if the diagnosis machines read CMP
timing retarded.
WHEN YOU ARE ABOUT TO MOVE THE CAR BEING HEAVY BUT FOR A WHILE STARTING TO GET MOMENTUM
timing retarded.
CMP definition
Camshaft Position
It is better to post the code numbers you are getting. Having said that, I would guess you have to replace the sensor.
The second part of your post is incomprehensible. Please rewrite it.
