2006 Hyundai Santa Fe - Gauge cluster
I have a 2006 Hyundai Santa Fe Limited. The problem I am having is when I first start my vehicle the instrument panel cluster doesn’t work. When the vehicle starts warming up then the odometer starts blinking and then the trip odometer will come on and blink also. The gauges will jump and get stuck because the odometers will blink a few more times and then everything starts to work fine. We took it to the Hyundai dealership and left the vehicle over night so they would see what it is doing. They did a diagnostic test on it and told us the whole instrument panel is going out. Has anyone else had this problem?
Does not matter if anyone else had this problem . You do and the dealer has given you a solution on this out of warranty vehicle. Your choice is let them fix it or try an independent shop but I doubt that will save you much money.
