2006 Ford Ranger - Just heat
New problem. Only heat comes out of vents. Temp control knob set to max cool doesn’t doo any good. Need to run A/C on Max to make interior comfortable.
It sounds like you have a faulty heater control valve. Go on YouTube and see Chris Fix go through a diagnosis scheme that includes the valve. I believe he shows this on a system similar to yours.
It was nice of the Ranger to have this problem now, rather than August :slight_smile:
Do the engine compartment fans turn on whenever the AC is enabled?
it could be a stuck blend door. blend door actuator could be bad,
this is for a 1996 ranger but you will get the general idea.
https://www.bing.com/videos/search?q=2006+Ford+Ranger++blend+door+actuator&&view=detail&mid=9D2EDDD5157D7A2B80BA9D2EDDD5157D7A2B80BA&&FORM=VRDGAR&ru=%2Fvideos%2Fsearch%3Fq%3D2006%20Ford%20Ranger%20%20blend%20door%20actuator%26FORM%3DVDVVXX
On a Ford Ranger it’s a blend door, and they do break.
There is a heater bypass valve to shut off the water to the heater core, but it only activates on Max A/C
Ford Rangers only have 1 fan, and it’s belt driven.
Belt driven engine fan? Surprising for a 2006, thanks for the info, good to know.
